I don't see  why you need to bother with briquettes when you can get all the quality oak firwood? 🙂
I'd just stick with rhe oak and maybe get some softwood also for kindling or to mix in for rapid heat etc.
Edited by Stere
10 hours ago, Gabriel82 said:
Probably. I never experienced it.
You don't want to which is why I mentioned it. Those packs don't look particularly sealed and if stacked in a damp UK garage you would just have a very big pile of sawdust by next winter.
  • 8 months later...
Sounds like the above was true and 6 months seasoning isn't enough for oak... 2 years is better.
I assume you are storing it outside or somewhere with a good airflow at that too - a mostly sealed garage will get damp inside for example, difference in air moisture and log moisture is reduced and drying speed slows. Don't stack drying logs to close together either, the stacks need air gaps for air flow. Last comment, taking a bucket of logs off the top of a wood pile will also take last weeks rain with it, taken from the middle might give better results.... but you'll knock the wood pile over trying to get them.
5 hours ago, Stubby said:
Oak takes at least 2 years more like 5 ! Also I would mix it with Sycamore or similar .
Yes oak does fry slower than most and if left in the round hardly dries at all but cut and split for firewood and left under cover in free moving air it will dry below 20%  mc in any of the months May till end of August in UK.
As has been pointed out the air has to be able to move through the stack and a log tightly packed deep in the stack may not dry very well but, as long as it cannot be re-wetted, over time it will reach an equilibrium with the surrounding air of less than 20%.
Most of my stack gets well below 20% in a year, I have no space to store more, but I still pull an occasional log which I can see free water from as it burns.
Another tip is to split a log before using a moisture tester to get a true measurement of the water still trapped inside.
In the uk, if you start early, split very small, stack outside for a bit, then bring undercover for a bit more, but still exposed to sun and wind, you might just season wood enough to burn that winter. But this is hard work if doing it by hand and a longer would always be safer.
Also you really tell what your wood is like with an open fire and the hissing, stoves burn any old wood.
  • 11 months later...
Oak takes at least 2 years to dry through to around 20% here in Scotland.
Often it appears to be ready but if I split a piece in half the inside is still above 25%
I have a store which passes the wind and is protected again rain by a mesh curtain (skip net) and tend too leave it at least 2, more likely 3 years.
I burn mostly hardwoods and Oak needs a friend in the stove. For this I use Ash or Birch and occasionally Beech.
I love Oak, it's well worth the effort IMO
If you are not going to have a " friend " in there I recon it takes 5 years !  Evergreen oak is quicker mind .
