2 hours ago, Jase hutch said:
From memory the first units Greenmech sold were electric drive to the wheels and hydrostatic drive came later.
That's interesting, what sort of electric wheel motors?
If I remember correctly it was a single electric motor and an axle with a differential . The only downside to this set up was that it could drain the battery unless operated with the engine running , this meant having the cutting wheel spinning as well !
When the hydrostatic model came onto the scene it had a clutch for the cutting wheel.
Pete Baggs might correct me ?
Jase's recollections are spot on. The electric drive was fair jerky to inch forward so some had some kind electrical slow start device to help. The electric motors could also ingest a certain amount of crud which could stop them fro  working too. When the hydro units were introduced, we stopped importing the electric drive. You could lock a a wheel with a simply, "over centre" lever with a cable down to a lever on band brake, the levers were vulnerable to getting bent though!
  • Thanks 2
Is there any way of finding out the year of my machine I can’t seem to find it anywhere on the machine.
What's the serial number ?
If you let Pete B know , he can easily tell you ?
Or if its : a series of numbers followed by a letter , the letter designates the year. K was 2000 , L was 2001 and so on.
Jase.
