Looks good!
I often thought about a 14/16ft ifor with crane, like the old jasp Wilson botex jobbies or that Truck and Marine do, but went down different routes.
keep the pics coming
looks cool , but the trailer capacity looks small, could you not of mounted it on larger trailer, maybe too heavy then.
what do you use it for?
Keep looking at these, the nose weights must be huge on a unladen trailer, and capacity must be under two tonnes probably closer to 1.5 tonnes, against an investment of over £10.000. Are they realistically worthwhile?
9 hours ago, dumper said:
What’s the nose weight on the trailer unladen?, did you have to balance the crane? Do you know the unladen weight of the trailer?
Not yet and when I first picked it up I thought it was going to be a problem with the jockey wheel winding up and down I thought it would struggle but you can actually wind it with one finger I am so over the moon and happy I am going to get an exact weight on the trailer empty and also I would like to get away on the nose hitch Will keep you postedWill keep you posted
2 hours ago, Stihl123 said:
looks a good build, i got one of the Jas P Wilson ones
is a very handy trailer
Lovely traI was going down the route of the same trailer would Botox crane but it’s far too long for me for the areas that I work my trailer is deceiving it looks small but the capacity of Logs is unbelievableiler I was going down the route of the same trailer would Botox crane but it’s far too long for me for the areas that I work my trailer is deceiving it looks small but the capacity of Logs is unbelievable
