So in your neanderthal caveman mind, you equate arguments with women or being gay.
I think you're more in need of a therapist, probably a Freudian mommy complex. Would account for the overcompensating and trying to be a big man, I have zero to prove and care even less who thinks what.
5 minutes ago, Stubby said:
Well that points to the pull cord assembly surey ?
Not sure. When I remove the assembly, I can't rotate the flywheel unless I free it off with a socket. I think it's the piston.
Yea but will that fix his saw ?
8 minutes ago, Will C said:
Can you turn it over as many times as you like with the pull cord housing off or does it still bind at a full turn?
Hi Will,
Yes it'll turn freely by hand once I free the flywheel off with a socket. The assembly/housing seems fine.
Good night Gareth. It's well past your bedtime. Thanks again for your help. You've certainly increased my rank on this forum with your posts and my replies. Probably the only useful thing that you've done by the way
2 minutes ago, GarethM said:
Nope, but chucking the POS in the skip would.
Definitely a menopausal reply. I bet your missus/boyfriend says the same about you lol. POS!
