Hi iv just bought a Farmi wp30 masterspliter I’m thinking of fitting a 15hp petrol engine on it to free of my tractor. Any one got any tip .hock
24 minutes ago, Justme said:
You will also need the right pumps as the PTO ones are different.
Would it not be as simple to simply arrange to drive the PTO stub at 540rpm, if that is the required PTO speed? In the correct direction of rotation of course.
I’d plan to use belts and pulleys. Following with interest.
Edited by doobin
Is it worth the hassle? I am sure you could sell you existing one for good money and just buy a WP36 with the engine already installed. Saw one for sale just yesterday
Then you will need a bigger engine to cover all the losses in a gearbox, belts / pullies.
Better to fit higher rpm pumps direct to the end of the engine. Mounts are stock items ect ect.
More to go wrong.
The benifit of hydraulic is no belts & pullies.
Iv’e fitted a 15hp engine to my farmi wp30 masterspliter , what pump do I need and where I can buy one . If I can not use the pto one  hock
Get someone with one to give you the part numbers on the pumps.
Failing that look for pumps that run at 2800-3000rom with the correct flow & pressure rates.
