Ah so your GM150 34hp chips @ 1800 rpm and the new Jensen and Forst 24hp @ 1360 rpm! Quite and significant difference of flywheel speed!
Wonder if the throttle can be adjusted to re-tune the new one to chip better?
I think weight of flywheel is a key factor, the heavier the more inertia or something.
Anyway, I’m clearly out of my depth so I’ll wait for the experts to correct me.
Don’t think forst do a 24hp diesel but I could be wrong and yes it can be tuned up on the injection pump but that would invalidate the warranty, once out they I wound do it.
Schisling 6 inch chipper runs a 3 cylinder 23hp engine and is a fantastic chipper.
Greenmech evo 165 will out perform most 6 inch 35hp chippers just like the Schisling.
Its short sighted to think that 6 inch chippers need to run at 35hp when 25hp is all you need with the right engineering.
All the Evo needs now is a turntable👍
All the Evo needs now is a turntable[emoji106]
But there 6” the Jensen in question is classed as 8”
I’m trying to do some digging myself but trying find info on the the new tier 5 24hp Kubota is difficult as I only seem to come across the v1505 E tier 4 documents? Just wondering how different the engines are, if at all?
We have the new 24hp diesel forst at work now.
The lower powered chippers won’t throw as well as the bigger stuff and struggle with greens, a mate has the Jensen a530 with a 25hp petrol and that won’t throw leaf to the truck but that is a joke!
