Best grass head for Stihl FS 461?
Pinkfoot
2 hours ago, Pinkfoot said:
What would be the best head for this machine and grass?
I have 17 small water pump sites that are cut once a month.
What is the most effective and efficient head for this job ?
Regards
Opinion will be divided on this one ! I like the Oregon Jet Fit heads with 3.00mm or 4.00mm square line made by Diamond extrusion .  Some people prefer thinner line with a bump feed head . IMG_20170619_180545.thumb.jpg.4942d30d76d3ea11e6758396e43aece2.jpgIMG_20170619_180519.thumb.jpg.57dda9c4781eede7c7dcc1ea9a2a1356.jpg
11 minutes ago, Commando said:
On grass, Oregon jet-fit and 3mm flexiblade line takes some beating imho. Just use two pieces in a 4 way head keeps the line speed upemoji106.png
Someone who does the same as me ! Also soak the line in a bucket of water . nylon is hygroscopic and absorbs water making it less brittle .
27 minutes ago, Pinkfoot said:
Stubby.
You haven't got the plastic cone on.
Is this legal 'cause you might die?
The plastic cone pissadears after a short time . Not worth bothering with . Its a 4 way head but with only  2 lines in the lower slots . using a 4 way head keeps the nut under flush so you don't dig in .
Edited by Stubby
