Hi all, I'm replacing the seals on my ms200t 2004
Can anyone tell me what the code is for new seals or if there is a better seal to fit other than OEM ones?
Thanks
I think you will find the small ms260 (flywheel side) fits and the 200t has the same both sides.
there better imho, and iirc spud has recommended these in the past.
You can see the part numbers in the pic's
Number 17 is the 260 & number 3 is the 200
and you can see they are the same dimensions
Edited by Wonky
Dimensions
