17 hours ago, Steve Bullman said:
One more question. This table isn’t ideal as far as where I can put legs on the thinner end. Can I build up this gap with resin then drill into it?
Would be awkward to use plain resin as it would need a mould set up around the edge. You could thicken the resin to make a stiff paste but that would be pretty expensive using bronze as the filler. Alternatively, you could use talc which is really inexpensive to make a grey coloured filler and maybe just finish the exposed edges with a different coloured filler? But, I doubt it would stick to the wood sufficiently to take screws for the legs, so the screws would need to be long enough to get a grip in the wood, if it’s thick enough.
I think it might be simpler to cut a recess and glue in a block of wood, then shape the edges. Or maybe flatten the surface and glue on a wedge shaped piece of wood.
Andrew
Andrew
Im going to get my chainsaw out again and cut a recess then screw the legs straight into the recess
Try a bit of carving at the same time Steve😂
Edited by gary112
5 minutes ago, muttley9050 said:
Good plan
Can’t quite tell if that’s sarcasm or not 😂
Can’t quite tell if that’s sarcasm or not [emoji23]
I wouldn't use a chainsaw for that job, but with limited tools the chainsaw is a good choice. I suspect you know how to use one anyway. [emoji848]
How,s it coming along Steve?
4 minutes ago, Steve Bullman said:
3rd coat of danish oil applied to the console table, waxing tomorrow. Tables not progressed anymore but might try to get the legs sorted tomorrow
Looking good,lovely piece
All waxed up, legs on, and screwed to the wall. Pretty happy with it although the piece of wood itself is a bit warped which is slight annoying, all part of the rustic charm though I guess
  • Like 10
