Hi All,
When it come to hedge trimmers, is there really much difference between the "rough cut" and the "trimmer" types, so for  example a Stihl HS82T or an HS82R or a Husqvarna 522HD60X or a 522HDR60X..
Will a rough cut one make a mess of nice hedges and will a trimmer one cut rougher tougher hedges??
Does this mean that i really need two of the things??
john..
Get the rough cut ones unless you are doing really tight topiary.
the trim ones move too fast and miss bits if you move even a bit too fast.
they won’t cut thick stuff
the rough cut will do both if you use them properly.
ive got both a hs82t and r version they t has hardly been used
I bought one today. I was intending to get the rough cut sort but got the trimmer one by mistake.. Bit late now though as i have already used it.. Did not look up the model numbers till i got home..
john..
