Oil setting
nemcc
21 minutes ago, nemcc said:
What do you guys recommend on the oil adjustment for an 18inch bar on a 500i?
I'm getting two tanks of fuel to one fill of oil at the moment on near minimum setting.
18" is not very long for a n 80cc saw . I would have thought that might be ok . Run it up with the tip of the bar on a fresh cut face or a bit of white paper and see what is coming off .
