Fs460
ChrisOdo
  • 1 month later...
On 20/05/2021 at 16:28, ChrisOdo said:
Currently using an fs460 for clearing. Frustrated with autocut heads and guards. Anyone tried a small head on it by changing the nut?  Or alternative guards without the larger lip?
Your help would be greatly appreciated
Have a look at Oregon Jet pro heads 4 blade will work on 460 i use the Techni blade shreds everything
I run 460s. No guards. 4 way head with 2.7mm cord for thicker stuff- twice the cords, half the wear. The smaller head with the larger nut and 2.4mm cord is my go to for grass and soft things like thistles, and I highly recommend it with no guard. You can run a fair length cord like that.
I couldn’t get on with jet pro heads. Always felt like it wasn’t cutting very efficiently as it had worn down a bit, but wasteful to change it!
You are like a Jack Russel with a rat  Ruben ! 😁
Other gear fits in the heads also been using some twist cord that stays in head ok so can use 6ft lengths ok!!!
Ok , ok . I can strim a cricket pitch in one pass 😁
