BG85 is different than the BG86, the 85 is non strato and the 86 most definitely is!
The BG86 needs a lot more warming up and when warm, I wind the H screw all the way out till is starts lowering in revs then wind it back in to peak revs then out around 1/4 turn to fatten up the fuel a little. This way you get the unit revving as it should....the L screw can be a bit hit and miss but you basically tune it so you get a good pickup.
My BG85.......well I modified it a bit and it pulls higher revs much better and works well.
The carb can be a bit iffy but mostly due to the primer check valves which can get stuck. Not a bad blower but I got mine for £25;)
On 08/05/2021 at 11:49, devon TWiG said:
fitted carb this morning and saw is running fine again !!   time will tell on quality of carb but issue sorted ....
Probably a Walbro carb taken off, poor idle stability,  revs picking up on idle and then dying, bogging but runs OK flat out but can scream are usual symptoms.
Interesting stuff re tuning. Don't suppose you know the part number for the tuning driver? I've got a 86 and it's been in the shop twice now for a retune and it still seems wrong. It won't rev at all when cold. If its left idling for 5+ seconds it bogs on acceleration and if I tilt the unit forward it revs up?
Edited by Paddy1000111
Could be an air leak that opens up more being pulled by the AV  when you tilt it ?
3 minutes ago, Paddy1000111 said:
Maybe. It's 3 weeks old. Back to the dealership.😂
Oh . I doubt it would be an air leak at three weeks old but defo back to the dealer though ...
It's just annoying. As I mostly rake and sweep as I find the blower makes a mess on smaller jobs it's only had 4 tanks through it but it's very annoying. Might take a gander myself before taking it back. Might be something simple
no , it was a zama carb ...
