http://www.logs.co.com/?product=the-garden-cube-outdoor-stove
Absolutely fantastic piece of kit.  4 glass sides. 1.5m flue. really solid construction and weighs 90Kg so its not going to move!
You can get you current "Rule of 6" around it, no one is getting covered in smoke or ash.
RRP is £1495 inc VAT and delivery to most mainland UK addresses. I'm happy to do an "arbtalk" deal for anyone interested. Please PM me.
Hi, what is the heat output like?
This is my unique outdoor burner. It’s made from two small old fire extinguishers, the flue is an old piece of exhaust from a coach and it has a small stand on the top to heat a kettle.
Burns a little like a rocket stove (complete with the roaring noise). Where the two extinguishers join, there is a small baffle plate into the upright one which does well in creating a vortex in the front chamber and a secondary burn chamber in the upright one. Very little
Smoke comes out and the heat it kicks out is incredible for such a small stove.
  • Like 6
Really Good. We load it with logs about 12" long and quite chunky, in a criss/cross pattern and burn it from the top down. Once its going, you can sit a comfortable distance from it, you don't have to huddle round it close to get warm!
We were outside in 2 degrees c for several hours a few weeks ago!
Had a few questions on the Garden Cube.
Its made in the UK, and really solid and well built. The cube has 4 glass sides which are completely and easily removable for cleaning. The firebox top and bottom are 5mm steel and supports are welded on all sides.
