Is there an easy way to spray timber fences??
Can u do it with an air compressor??
Got a decent sized compressor that I use for normal spraying can u put it normal fence paint thro it??
Does it make a decent job or fine mist everywhere.
Its for my mother's fence, its ranch style, it's a fair length and she's stapled net to it for sweet peas etc to grow up and flowers and bulb everywhere, be a real pain to paint.
Is a gravity spay gun best or is there other kinds?
Or do u dilute the fence paint with water?
Cheers
Airless sprayer is easiest. If using air compressor then you’ll be refilling the gravity fed pot every two minutes unless you get a static paint pot with a wander hose.
Cheers.
Silly question but wots an airless sprayer?
Is that like the knap sack or weed killer type?
Top wot type of set up do u use?
Just gravity fed gun? Water fence paint down?
Where it's it should be ok for hitting non target things, but I know it u mean just spray painting in general
