Getting kind of fed up with using a file now and after using those electric angle grinder type sharpeners before and hating them with a vengeance, I've seen a fair few posts about using a Dremel for sharpening. Anyone got any feedback? What bits are you using/who from and are you using a jig of any sort?
Thanks!
Ideal! I just want something to fix a chain with when hitting a stone or something. I was losing the will to live the other day after clipping a stone under a log that was stuck in the ground.
6 minutes ago, Stere said:
Do you have a compresser?
You can get little air grinders
WWW.EBAY.CO.UK
Rear exhaust,to prevent the chip flying nti-chip scattering, noise. Includes 10 grinder heads and built in speed regulator...
Not tried mine for sharpening yet
Funnily enough I have one of those already! I have the battery dremel too so I was hoping to find a good kit for that for some quick, in the field sharpening when I hit a rock or nail or something!
Those are the days you want one for. Ten years ago i would have given my eye teeth fr that buy, on 30"  bars  that walloped a nail. Gently whacked them  back with angle grinder then used a box full of files  😕  k
