8 hours ago, stewmo said:
Any tips on what to look for as I understand opening up the handle can get messy
A loose tie wrap round the handle works :D
This was mine, I’ve got different plastics for it.  I couldn’t be bothered to even start to think how I was going to start on the starter cover grill, also the coating was well chipped and the mag had a lot of oxidation. So I settled for the let someone else do it 👍👍👍
OK, lets end the love in...the issue will either be the throttle trigger or the control shaft - that is the white plastic bit that all the kill wire contact springs run on or the bit you stick your finger on to make the saw go loud.
It is always one or the other.
In the picture - (pinched of Paddy) shows the fast idle mechanism latched. The two arrowed parts are the bits that need to latch and one of them will be damaged...fact.....I thank you😉
Edited by spudulike
Someone had to step up and do what I didn't have the effort to do... add arrows!
That lip on the control shaft is the more common one but the throttle trigger can brake its end off giving the same issue.
TBH, I didn't read your post as the pics caught my attention😉 Thought you were just posting chainsaw porn!!
In the picture - (pinched of Paddy) shows the fast idle mechanism latched. The two arrowed parts are the bits that need to latch and one of them will be damaged...fact.....I thank you[emoji6]
DSC_0251.JPG.9f0f046e43b658c9b910465cb2d3b30a.thumb.jpg.af12cabc71335c8d6a4263046bd05d11.jpg
No....thank you spud
22 hours ago, spudulike said:
That lip on the control shaft is the trigger
Hopefully I fixed it for correctness...🤩🤩🤩
we like chainsaw porn 👍👍👍
  • 3 weeks later...
