I have an old Japa 2100 firewood  processor which does all I want it to do.  Recently while processing lengths  of  cordwood into logs the chain /bar jams in the wood I am cutting through.  Is this because the chain is blunt and the bar has a slight burr on it due to excessive use.  I have  had the machine from new 14yrs ago but the problem I have described has only started to occur recently.
Had a problem with my Farmi doing this one summer. A combination of using some different chains which were more aggressive and very dry ash. Swopped to a semi chisel chain for that batch and all was fine
Edited by Woodworks
Thanks for your replies. Sorry to have mislead you @dumper .
I sharpen the chain on a regular basis as needed as I log up about 200tons of cordwood each winter.
I think my mistake is not filing off the slight burr on the sides of the chain bar each time I sharpen the chain ,also getting chains and bars does not help ie putting a 1.3mm wide chain  in a 1.5mm  wide chain bar!!!!!!
We live and learn thanks again and I wish you a safe 2021.
I had this years ago .if you still have a problem  My hand sharpening caused larger teeth one side than the other . Which made the bar try and cut in banana shapes . Solution bench grinder every now and again or new chain .
