We have a S725tx, just wouldn’t be without one now, we run a winch, log grab, bucket, log splitter and a flail off of it. Don’t give it a second thought just go and treat yourself and save yourself a lot of hard work.
Dumper
Do you find you need much more than the cormidi will lift when doing trees? I've got an oldish boxer with a tipping capacity of just under ton, I find its plenty enough. Basically what I'm asking in terms of lift do you find yourself wishing you should of brought the avant along instead of the cormidi much?
Cheers
Hi Jim
What flail are you running mate? And how do you get on with it?
Cheers Matt
Loaders of some sort are the difference between one level of tree company and another.
You really have to have one if you are a serious outfit competing for larger take downs/work.
Edited by Mick Dempsey
18 minutes ago, Clicky said:
Dumper
Cheers
If it’s mud I take tracks I’ve made a head stock for the Cormidi so it can use all the avant attachments,they do different jobs as a forklift track loaders suck,for flail mowing run tracks no punctures, going long distance on tarmac or concrete use wheels using a bucket both about the same cultivating I take tracks, I adjust the jobs for the lift capacity trying to keep the weights moved as small as possible
the Cormidi will tip at 1250kgs but running at that weight regular knackers tracks and rollers very very quickly
you always wish you had a bigger one!
Edited by dumper
Got ya nice one mate cheers, but yeah just get one OP. No one likes lifting wood, worse thing about loaders is when you can't get them into jobs the job sucks even more
No issues with it? Are the attachments easy to get for it or does it need a special head fitting to it?
