Yea 100% Go with the Sena smh10r. It's the perfect system and installs easily. The only negative is the wiring is very thin as it's designed to be in a bike helmet. I bought some 3mm expandable braided mesh sleeving and fitted that to all the wires and used fabric harness tape on the ends of the mesh.
2 hours ago, brynarw said:
And does the expensive Protos system work in a mixed group with Sena users? Thanks
I've never tried it. To be honest I don't know anyone who sank £420 on one pfanner bluetooth headset when you could buy the sena set and have dual channel sound and all the mod-cons with it
On 12/12/2020 at 17:25, AWarb00 said:
We have Sena SMH10R 's , work perfectly
Once you have Comms you wonder how u ever went without them
Sounds good (forgive the pun) I'l check em out. Thank you
