Just now, spudulike said:
There is on my McCulloch.......or there was before I removed it!!
Is it one of those ooooold skool ones?
I've seen a few 2-strokes with separate jugs and heads, but 2-strokes are definitely not my area.
The big one ?  Probly so you could decoke it every month 😉 K
It sort of makes you wonder what the thought process was? Perhaps some experience of other equipment??
The Yanks call them jugs for a reason! Just means something else this side of the pond.
Well it isn't one of those ones from B&Q😉 Yup, the 80cc one and is curiously difficult to pull over now! It was just a plate of aluminium about 1.5mm thick.
Maybe all manufactured by someone setup for casting lots of air-cooled 4-strokes? Or if it's a plated bore maybe something to do with the machining and plating of the bore. Simpler to machine a through tube than a closed one?
Thats the Jessy plate mate!  Lowers compression  😉 make sure ye have yr 3 weetabix tomorrow !  K
