Farmi wp36 Road tow Processor
Woodsman1967
That is one of the earlier models. If you put it over weigh bridge you find it well over the axle limit! The newer ones come on an uprated trailer and axle. Check what the cycle time is on the ram as I think some had a slower time than the more up to date versions with two speed rams but dont know when they changed. It does look very little used for sure. The aluminium conveyor paddles are better than the rubbish plastic ones they have now. Check the in-feed of the ram as some of us have bent that part. Cost me 1k to replace. Great little machines
As above that will be over 750kg & need a braked trailer.
My wp30 is smack on 750kg with the lifter hydraulic oil & a tank of gas, With the extra length of the conveyor & bigger ram, extra pump ext it will be well over.
New they start at about £12k + vat.
Edited by Justme
  • 5 months later...
