Sorry guys I just saw the response now. Thanks for the response struie.
unfortunately the tool I’m talking about seems to be one Stihl have made this year, and isn’t actually found anywhere online or in any of the kits. I’m not referring to the standard 4mm hexagon they’ve used for a while, it’s a new octagon screw they’ve started using.
That's strange, I have adjusted BG86s and they have been phillips adjusters. Often another adjuster will push on and fit even if it is the wrong shape. Perhaps the spline, Hex or pacman may work?
  On 21/11/2020 at 18:01, TheMulchingMan said:
It’s on a Stihl BG86 but I’m assuming they’ve started using them on other products too?
I’ve attached a picture of the screw
thanks
Expand
WWW.LSENGINEERS.CO.UK
Hexagon Screwdriver 4mm Across the Flat Edges of the Hexagon Shape Genuine Stihl Part OEM No. 5910 890 2307
If it's not that one then do you know the numbers on your carb?
Edited by Paddy1000111
Read more
