Hi got a customer after a slab for a dinning room table
Needs to be about 6.5 meters long
Min width 850mm
Max width 1600mm
Ideally after something that's already been in the kiln
Doesn't really matter too much what wood it is
Required in Ipswich, Suffolk area
Please dm me if you'd have anything suitable
Cheers
4 minutes ago, john meehan said:
I’ve a stick that might just be about that, only recently felled though.
I can measure it tomorrow if you like.
It’s oak.
Cheers John
Ideally need something that's basically ready to go
I'll let you know if I get stuck
Thanks mate
If not, I'll have to drive up mate and get one off you  [emoji23]
You won’t find one.
Will have to be cut to order.
Do you know how thick that would need to be so it didn’t tear itself apart?
And how heavy??????
I hope you’ve taken a massive non-refundable deposit?
And given your client a 12-18 month lead time?
[emoji106]
3 minutes ago, Rough Hewn said:
You won’t find one.
And how heavy??????
I very much doubt its going to be easy or possible!
The customer spoke to someone today who said he'd be able to import a bit no worries but I have no idea what it would be like
I said I'd try over here first
Vastern timber are the most likely to be able to come up with something.
