Husqvarna 435 wont start driving me nuts
On 23/09/2020 at 15:15, CEE said:
ive actually ordered another new carb
It's not such a long shot:
I know fuel is in the bottom of the carb - you can see the bulb pulling it through.
I know air is going into the engine.
I know that there is a spark (but i've ordered a new coil just in case) The existing coil tests at 0.5 homs so it's bang on spec
I know the timing is OK becuase the keyway is intact
So I only need compression / vacumm under the piston to go along the umpulse pipe and for the carb membrane to do it's job and pump the fuel.
I think it's hugely unlikely that the crank seals have gone (but i will go there if needed)
if the crank seals are intact then there is pressure in the impulse pipe and fuel should pump
so it's back to carb
Let's assume that the original one went wrong / got clogged - it wasn't the best in the work when I reconditioned it. Maybe my clean out didn't work.
Then the new aftermarket one I bought had 4/5 stars on Amazon so lets assume that 10% of the carbs they sell don't work
I really could have 2 duff carbs - it's not 'that' of a long shot
So another new carb coming....
Have you tried slaughtering a lamb on the Altar of Huisq ?? At midnight with the Shipping Forecast blareing on R4 ?
 Seriously tho' yr right , sometimes these cheap China Bloc saws actually just do the job . The screaming frustration of an expensive saw blowing out is horrific . K
( Mr @Stubby  the promised leaf blower ( McCullouch ) arrived today , started first time out of the box, got my ' Ride of the Valkerie ' Wagner tape ready and a red smoke bomb we used for Badger burrow shennanigans - just waiting fr the neighbours to return from holiday ...... )
Edited by Khriss
spelling
Don't worry I am very very close to droping the thing on ebay for spares / repair. The OEM coil is the last try.
If it ges junked I am going to get a Hyundai 6220. 3 year all inclusive platinum warranty and then if it goes wrong it will go back and I will just ger another cheapo. I am not a heavy user.
I could do with a bigger machine cos there is a large oak trunk down on my friends land - about 6m long and about 33 inches across and he says I can have it.
@CEE yr clearly no muppet in the workshop, from yr descriptions - its the time and frustration.  I fit ebay parts on mine and most of the time they score - can't be bothered with dealers at all .  K
How the other half life , honestly ! ☺️
17 minutes ago, peatff said:
I'll swap it for my old Dynamac, starts and runs like a champ :D
I will raise you your " old Dynamac " and offer a used stunt scooter and some chocolate covered Brazil nuts my Gran had in a cupboard ....
