Lo Pro Bar maximum length bar Stihl ms661cm
I use a 48" Lo Pro on the 661 form milling. It starts to struggle on harder woods, particularly if they have been down for a while but is a useful setup if you are meticulous with your sharpening. Larger than that I switch to the 880. I would have thought for general tree work it would be too slow.
Edited by CDMR
Thanks for replies. I use a 48” lo pro bar. I have seen a 64” used online ok. Is as just curious if anyone has tried what I mentioned but I pretty much guessed not.
right then, what are these Lo Pro set ups like?
thinking about getting a 36" set up for my 660? it's ported so got got some good poke (to lowest limits so it's fine for milling before u kick off)
i have an 880 as well set up with a 36, anyone here run a 660 with a lo pro 36 and also a 880 running 404 on a 36, if so, if u have both of them sitting there, what do u pick up?
really interested as i've thought about selling 880 as i don't use it much and then changing over to lo pro on 660
over and out
On 24/09/2020 at 19:58, Rough Hewn said:
Get an 880.
I bought a 3120XP for milling and big stumps.
I bought it on eBay, went to collect it and picked it up off the ground and instantly thought "What the hell have i just done?" ?
The damn thing weighs a ton! The 880s and 3120s have their place but god damn are they big fat heavy things!
(And not as fun to use as i thought either.)
I bought it on eBay, went to collect it and picked it up off the ground and instantly thought "What the hell have i just done?" [emoji23]
Wait til you move a 12’ x 4’ slab....
???[emoji106][emoji106][emoji106]
