  On 19/09/2020 at 17:15, HDAV said:
After this I think I’ll have a bash at an outboard motor ready for next spring.
Expand
That's what is on my bench atm, a 4hp Johnson, cleaned the points and put new plugs in and it fires up fine, just got to see why the water pump isn't circulating.
Bigger job is deciding how to repair the floor of the inflatable, the internal joint between 3 of the ribs have sprung apart.
Expand
If your not  a member pop over to Rib-net if you need any help
WWW.RIB.NET
Inflatable boats - SIBs and folding RIBs - Not RIBs, but SIBs or Soft Inflatable Boats. Small RIBs too, anything that can be...
 I’m sure someone there will tell you it’s dangerous and you need to skip the lot ?
  • 1 month later...
Managed to strip It down totally to the bare deck and make a start on the repair, first couple of layers of glass and resin cured, used a surprising amount of matting already so may need some more ? but see how it looks once I have finished The pack I bought.
Edited by HDAV
Bit more progress, getting closer to reassembly.... cheap filler isn’t a good idea ?
Glad I started small I nearly bought a boat.....
Read more
