waterbuoy
Stihl 066 starting issues
The ignition module is still available and is used for at least 3 different flywheels on the 66 if my memory serves
Share this post
Link to post
There is a Stihl document on which flywheels and coils go on which machines. The flywheel part code is, helpfully, on the back of the flywheel!!!
Share this post
Link to post
Share this post
Link to post
1 hour ago, Wonky said:
If the husky’s good, I’d send the 066 off to that same person, for a full service. 😉
Rest assured that is where it will be going if necessary - we are already 'in dialogue'.
However, I have some work for it to do over the next week - we are taking down half a dozen large spruce trees around our house (about 120' high with a dbh of around 3') so I will need the big saw for that.
Ashamed to admit that I managed to get somewhat distracted today due to a new arrival at the other end of the scale - a Makita DUC306 cordless top-handle.  What a great piece of kit for the money (£170 plus VAT).  I spent the afternoon clearing the lower branches from some of the spruce and one very large (I think) Leylandi (taller than the spruce) and only had to change the batteries once.
Share this post
Link to post
Think the module starts with 1122 400 can't think of the last bit.  I'll double check tomorrow with which flywheels
Share this post
Link to post
Take an old plug, bend the end electrode out at 45 degrees or take it off completely then place it in the cap, earth it and pull the saw over hard and fast. If it sparks - there aint much wrong with the flywheel or coil!
I wouldn't get too hung up on these parts unless you have no spark, the saw has strange cutting out issues or fails when hot.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
