Husqvarna 165rx, 265rx brush cutter differences?
The 165 was around for a good few years and was replaced by the 265, it was a very similar machine, from memory the gearbox, top cover, air filter, muffler, throttle handle were some of the main differences, was there a reason for the question?
I repaired one of these 265rx with @adw's help and it is very similar to my much earlier 165r, one obvious difference is the on off switch being part of the throttle control on the 265.
There was no power gain between them, the Swedes always boasted it was the largest clearing saw in the world, far to powerful for a trimmer head, it was really a clearing saw not grass cutter
When I got my 165r in 1973 the saw blade was the only option and then the tri blade became available
Using plastic string to beat grass didn't appear till a few years later and yes the strimmer heads that became available didn't last long on it.
BTW @adw mine has lost it's spark was the coil common to other machines?
