Like a chainsaw, only smaller!
TuscanPhil
I have a Lidl Florabest multi function 2 stroke tool (strimmer, brush cutter, hedge trimmer, pole saw) which is ok, bit heavy, but cheap and cheerful.  Sadly, having come to use the pole saw today for the first time (I've had the tool for a few years but never wanted to use the pole saw), it turns out the little pipe that takes the oil from the chain pump to the chain is split and hence pisses oil out before it can get to the bar and chain.  Working on the premise that it could be very similar to another small pole saw, does anyone have any idea where I can get a replacement oil pipe from so I can actually use it now that I want to.  The cutting head is the same as the one in this video and the pipe is probably about 6" or so long but it not just a piece of pipe as it has rubber flanges to hold it in place, ie it doesn't just push through holes in the tank/casting like a fuel hose would (I have spare fuel hose but it wouldn't fit and be usable for this).
7 minutes ago, Khriss said:
Bastard  ? K
(  I got one of these an there are loads of spares on ebay mate, just have a look. Squirrel ate my oil tank n got new one fr 7 quid. )
I've already looked on ebay for them or the full chainsaw head - can't see any at the moment, other than a full new head at around £45 from Germany.
WWW.EBAY.CO.UK
Find best value and selection for your...
Blokes like this. They are out there. K
