So why not a good set of long aluminium ramps an I for trailer with electric winch with snatch blocks and a ground anchor or decent mount on the trailer should be good for logs up to the trailer MAM, Would move more than a crane
17 hours ago, kav said:
I’ve purbuckled (i think thats the right term) some decent lumps up ifor ramps using truck winch or petrol capstan. The capstan is nice as uses rope
That's OK if you have room to work not easy if at  roadside.
Scraggs on here has the best I have seen.
Edited by woody paul
hopefully he will upload a pic or 2.
Yeah that is pretty much what I was thinking.  Not sure whether to mount the winch or have it loose for flexibility.  And as you say a ground anchor will be necessary for bigger logs.
