BTW if any of you need your logs checking for nails, send them down here and ill put them on the mill- that band will find them EVERY time without fail:thumbdown::laugh1::laugh1:
hahaha that is soo soo true!
I believe this virgin had been penetrated ! I’m lucky I did not tread on it# shure you not burnin pallets?
How very dare you i only burn logs. Does not help when all the past estate workers fix all fencing to trees. We felled a dead oak last year with the park fence in the middle of it:thumbdown:
Yep I know exactly what you say found this with metal detector and missed it thankfully !!! the timber was incorporated into a green oak timber framed workshop and garage with the stained wood and offending item used as a feature
