Mower engine needs fuel pump button pressing
cryptogram
Hi, I have a Subaru engine on my Ryobi mower and until it's reasonably warm it needs the priming button to be pressed every few seconds, or it appears to run out of fuel but picks up again when I press the priming button. Is someone able to tell me which part to renew to correct this?  Thanks.
What model engine is it? we had to stop using the rib in Subaru engine as could not find a reliable spare part source, a good engine but let down by spares back up, engines plus were the importer but lost interest real fast.
It's an EA190V engine. Have you experienced my problem? I get round it by having a clip on the handle so that I can let go, having started it, and rushed round to the front where I can press the priming button several times. This keeps it going for a couple of seconds, then it spits and makes to stop, so I press the primer several times and it kicks back into life. I do this for about half a minute and the engine seems then to be warm enough to go without this performance! I could get a new carb, I suppose, but do I only need a part of it?
I suspect this is a bit like the B&S engine that has no choke, the primer not only fills the carb but squirts excess fuel into the choke tube. I have a mountfield which is just the same, I leave it ticking over for a while before using it seriously.
Old british bikes with Amal carburettors had a "tickling" device for cold weather starts which lowered the float to let fuel spill into the intake, over use was a sure fired way to wet the plug.
Might need a carb kit. One of the diaphragms acts as the pump to drag fuel into the engine.
edit just read that it goes eventually properly!
have you had the air filter out and tried without that on. As in take out and close back up and see what happens?
Edited by Richard 1234
Openspaceman, I think you've sussed it but nevertheless, what bit has gone wrong that means I have to keep priming it to make it run? I have to say, it only takes about a minute before it starts to run properly but I'd like to sort it if I could. I don't need to leave it ticking over like you do your Mountfield
