Just been checking through bits so now the K'in fun starts!
Stihl 3/8 063 uses 13/64 files but if get the Oregon type it's 7/32?
So now go to one on 372 which  is running Stihl that looks like need 13/64 file now!
Then need to work out 044 chain as think that isn't Stihl chain could be Oregon or Sarp?
5 hours ago, AngrySquirrel said:
nothing showing up
Its not THAT critical . You can make it cut with pretty much any round file in the saw sharpening range .
I agree 1/64th here or there won’t make a discernible difference in the real world. More important to get angles correct, correct height and shaped rakers. As “Bucking Billy-Ray” would say “gotta clean out the gullet”.
yoo yeah dar dam boys can throw chips!
I'm sure some of them are smoking something!
If you are using short bars under 20".
You shouldn't have problems.
It's when you have a big bar sharpened with the incorrect file size you get problems.
But what is the correct file size?
As different companies use different sizes...
It's a journey...
?[emoji106][emoji106][emoji106]
The Oregon 3/8 chain has a taller cutter than the stihl chain. That’s why it specs a larger file.
Interestingly the stihl 13/64 files are boxed as 5.2mm and the Oregon 13/64 are 5.0mm.
In reality I’ve seen people get either chain to cut fine with either file, it’s down to preference. I prefer the 5.0mm ones myself.
