Just servicing the chipper at 94 Hours, was last done at 50 hours. However I’ve noticed the inner air filter has parts of the filter mesh missing, any ideas as to what would cause this and has all the crap gone into the engine? Genuine filter purchased from a Greenmech dealer.
  • Sad 1
That looks piss poor. Raise the issue in writing with your dealer ASAP so it's on record.
Realistically it's unlikely to have done any damage. Soft filter medium will have burnt up and as you've discovered the issue early on (and outer filter is in place?) there's not been any chance for abrasive dust to enter the engine for a prolonged perios and cause wear.
Yes outer filter is in place and no damage to that one.Β
On 12/04/2020 at 15:41, Jase hutch said:
Hi Shaun ,Β
No I've never heard of this before.
I'm furloughed at the moment but if you email : [email protected]Β
You should get a reply from Spencer as he is picking up emails and he handles warranty.Β
Jase.
Surely it’s not, but I’m no expertΒ Β ?
I have seen a lot worse on filters before now - you should see the filtration on my Stihl 090 - nonΒ existent compared with the saws today! I wouldn't worry over much but you did the right thing in checking it out.
Cheers PeteΒ ?
That’sΒ on a par with CautracΒ telling me a cartridge oil filter is washable. Unbelievable.Β
Β
Don’t listen to the muppets above shaun.Β Β ID the engine and get a decent replacement filter. Then invoice themΒ for it.Β
Β
Also check that there are no restrictions in airflow to the filter box. To suck the medium out of a filter means a shitty filter or the engine struggling to draw enough air.
Edited by doobin
Thanks for your comments Doobin. With only some 38 years around timber machinery, I wouldn't call myself an expert but, I would like to think that I'm no muppet either! Speaking as someone who has only had some 20 years working for GreenMech, I can confirm that the engineeringΒ  acceptance has always been signed off by all of the engine suppliers that we have used and the filtration is something that is included in the testing.
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
