20 hours ago, Dazonit said:
I'll give it a go tomorrow mate
Should the metering lever be set level on this carb . Just watched a  video on setting it
Cheers spud
The saw has used a number of carbs over the years but the ones I have done, the metering arm is set level with the surrounding metal around it and not level with the part the diaphragm sits on like the MS200 C1Q
Edited by spudulike
Well new fuel. carb cleaned .metering arm set level .adjuster screws 1 turn out and she is running sweet again thank you all for the advice much appreciated
Cheers all daz
