Anyone here sources a replacement tipper subframe for a transit or similar. I have a transit with a scattolini tipper. The van and the Arb back are in excellent nick but the subframe isn’t. Boulter tippers at Basingstoke built the conversion for me and could fabricate a replacement although quite pricey. So wanted to investigate if there are other options off the shelf so to speak.
Anyone here replaced theirs ?
Hi there,
A decent fabrication / engineering shop should be able to knock you up a new one. Unless you have something special it is only a box section frame welded together. Ideally it would be better to lift the back off and unbolt the frame from the chassis so they can copy and get dimensions right. (They could do that if they have a fork lift) If the back is good then it might even be worth getting the subframe galvanised so it lasts and can be transferred to your next truck.
Has it actually rotted through or is it just surface rust atm? Them one stop sub body's are tin thin and only last 3 - 4 year before they start going dodgy if its surface rust take it off get it shot / soda blasted then galvanised and it'll last a good few years
Jack
Jack
Sadly it’s shot. Not repairable.
I'd get a fab shop to build a new one and get it galvanised you see them body's on 14 15 plate trucks and there rotten really bad metals used so get a decent steel one rather than folded tin and galvanise it and it should last a good 10 - 15 year if well looked after
Jack
You’re not far from me iirc (midhurst) Drop in with it and I can take a look for you.
Are you able to fabricate a new subframe ? Cheers
So long as Parker steel remain open[emoji23]
I’m out topping fields at the mo. Drop me a message on 07780614112 and we can sort a time to bring it down.
Cheers [emoji106]
