Drilling Cannon Super Bar
gonger
Going to post some pics when i am in my workshop.
Yeah it was designed for clamping. But this takes just too much time for chain changing.
I stopped the time and were by 5 minutes for my 107cm GB bar.
In my opinion the time wich i spend at the milling place is really valuable.
My goal is to slab one whole tree , load it up to the trailer and store it in my workshop 1. Floor in just a day.
Don't drill the bar.
Just clamp it.
If you want a faster professional mill setup get a horizon panther mill.
And learn how to sharpen the chain whilst on the mill.
I only use one chain in a day milling unless I destroy it hitting inclusions.
[emoji106]
The panther mill in my opinion just has 2 advantages.
1. Easy height adjustment. ( Doesnt matter to me, since i have my Jigs for various thicknesses)
2. Sturtier profiles (30mm works just fine with 107cm, if it should be sag on the 150cm i am going to use 60mm)
That dont justifies the big costs on it. But if would definetively buy it, if i just would start from new.
Why should i sharpen in the field, when i can change the chain in 5 min? In my Workshop i have a MAXX Chainsaw grinder, wich is going to do the work afterwards.
@Daniël Bos
Dont want to drill there. I think than the underside of the Mill is going to interfere with the chain. Also i think, that this is going to increse the sagging of the bar, when milling.
@Rough Hewn
As wanted, there are some pictures of my mill:
So you would definitively drill on the #3?
Would it also be an option to drill in the small rivet, on the right side of #1?
Edited by gonger
Don't see a problem with drilling where you have on 3rd / 4th picture, ok so your loosing a few inches of capacity but with all Alaskan type jigs you have the same dilemma ....to clamp through the sprocket is no doubt possible but would probably require to be a bit more of an engineered solution than just a bolt, and as said the rivets aren't designed for that direction of stress and could be a weak point, but possibly not.....you'd have to try it to find out.
I also sharpen in place but I get your point about just being able to swap chains.?
