Clam shell bucket/basket for loading logs on forwarding trailer crane.
Due to new regs I am considering processing logs this May and storing loose logs in weldmesh structures  in an open barn to air dry them. I need a way of lifting the loose seasoned  logs out of the weld mesh structures and dropping the logs in to my pickup ,so I would like to know if any  of you have made  a clamshell bucket or basket that will fit on your forwarding trailer crane to load your logs.  Many thanks for any suggestions.
Edited by cessna
Not sure how good one would be picking stuff up out of a cage(unless it’s a very wide one)
More suited to picking off the ground or from an open pile.
i could be wrong though
Got one on ours , quite good on logs but needs a lot of space to use, the ones that slip onto a grab are a bit thin for log or stone, fine for chip or sand but will bend on logs.
