The seal on the shaft that you can see is only a case seal, as in it shouldn't be getting any pressure behind it. Its not unusual for wire and crud to get in there an chew up these seals, worth putting a new seal in and see how it goes. Certainly worth changing the hydraulic filter because its a filtered return system so if blocked could increase the hydraulic motors case pressure.
Bob
Typical of the sort of crap you can find around the motor shaft.
9 hours ago, monkeybusiness said:
Hydraulic motors are ridiculously cheap from Flowfit too. They’ll match whatever is fitted.
Be wary as their stuff tends to be chinesium build!
I’ve had a lot of stuff off them over the last few years (including a replacement 12v tipper unit for an ifor williams trailer at a bargain price, a number of complete rams for various kit I’ve had fabricated, big cetop operated valve blocks to set up radio control on a bandit chipper, loads of hoses and fittings, new electromagnetic coils they have identified from photos etc etc) and it has all been top notch stuff. Nothing has ever arrived that I felt was of poor quality - quite the opposite to be honest. And they are really helpful on the phone too.
