low ground pressure low weight crane / Man basket
AK Contracting
NMS can provide their Böcker AHK36 2400 trailer crane / powered access platform.
With outrigger loads of less than a 1t, variable jacking and the ability to be used as a crane and a man basket within 15 minutes makes it ideal for those hard to reach places.
Towed by a pick up, makes for efficient mobilisation and no need for artic access.  The crane is capable of self driving up slopes of 20degrees and self levelling on jacks on slopes up to 10 degrees. outriggers can also handle a step of 250mm between jacks.
designed as a crane or mewp allows for man basket duties up to 26m with 250kg payload in 12.5m/s and capable of lifting 2t close in and up to 100kg at 24m radius.
contact [email protected] or 01955605440 for any more information.
Edited by AK Contracting
its an efficient platform to work with when you consider that as a mewp you can reach 26m and around 22m at 15/16m radius and it doesn't need a lorry to deliver and collect. And weighing in at 3.5t you can go a lot of places without it sinking which you couldn't with more conventional equipment.
tow it with a tractor and I reckon it will be able to go to 96-98% of places tracked machine could go
Nice machine but how much expect north of £65.000
18 minutes ago, AK Contracting said:
ball park to our spec you wont get much change out of £150k
That’s going to make the hire rate steep not much different to a mobile crane and far more than a tracked mewp and it’s far bigger than a mewp
Edited by dumper
Spelling
comparable with a spider crane and day rate may be higher than a tracked MEWP that can go to 26m, but you don't need an artic to deliver and the weight is significantly less.
tracked mewp will be similar to a conventional so your looking at 3.5t on ours versus 18t ish on a conventional, so a higher day rate will be offset by transport costs and ground prep (if needed)
