Having problems with a Jensen chipper, keeps melting the coil on the hydraulic solenoid for the feed rollers...
Has anyone else had this idea? Not sure if its because I'm using incorrect coil, or because the oil is getting to hot and melting the coil causing it to break down / short out....
Works perfectly for 3-4 hours, then kills it and pops fuse and coil reads virtually short circuit...
Any advice greatly appreciated..
Thanks,
we had one completly melt once, fitted a new one and then it was fine, ours is usally too hot to touch during use,
not much help really i guess just double check you have the correct spec replacment coil.
carl
Hmm, forget model (Its a customers), will have a look tomorrow...
This one also gets very hot... just not sure if its because the coil ive replaced it with is a cheaper (lesser) unit and cant cope with the high heat, or if i have a problem, just seems odd the original one burnt out, and then the replacement one...
The original one was 12v 22watt, the one I have now is 12v 20watt as thats the biggest I could find...old one does look a little bigger / and feels a little heavier though... But struggled to find the 20 watt one that I have now, so if anyone has any ideas on where I could find one that would be great?!
Thanks!
I have had a couple of them pack it in.I bought an identical one from a company that sells hydraulic cranes.
Just make sure it's not getting current even when the ignition is off.That would explain it melting two.
If for some reason the owners run the chipper with the rollers slowed right down,that will heat up the oil to the point of boiling it.But I'd say it will come out of the breather on the tank before it melts the coil
At a guess I would say the plunger  has restricted movement and the coil is struggling to retract it,its worth taking it out and checking the plunger movement and condition of the o rings.
Bob
Edited by aspenarb
Because Bobs illiterate
