13 hours ago, Dilz said:
Yeah my mate is on about a cheap copy and or a cheap band driven machine.... but reckon in a couple of years they'll be shot.
Do you find the muck truck marks grass easily? is it easy to turn with a full load??
Wont mark grass much. To turn with full load, it's easiest to stop, lift slightly (it's perfectly balanced so not hard to do), tunr it on the two front wheels then press the lever to go again.
Hi doobin
I would use it for moving
logs
lengths of wood on the deck type fitting
pulling my branch logger and log splitter about
pulling log arch
on hard tracks and cross country
Also to move stone for patch up our access track
possibly horse poo removal
and general,garden tasks
wondering how good it is off road ?
thanks
They're brilliant offroad. Thick mud would slow them up, but then you should be using a track machine anyhow.
The main thing to be aware of if you plan to use it for pulling stuff about is that the only place you can really fit a hitch is the front. Which means you will be in reverse. Which is painfully slow, too slow to be efficient.
