Not sure if your suffering the same as I did with my 261cm. Is it the mtronic version. I hade almost exactly the same issues, turned out to be a coil. Have fun there quite nice saws when running well.
@lofty123 I think there is an improved solenoid, which is white I believe. The black ones weren’t all that good apparently. I found part no on another forum.
Did you get a cheap carb in the end? Found any other gremlins. My build has stalled while I save funds for a case splitter, think I may get both?
Do you know the number on the old or new coil? 4701a or 4702a maybe?
The carb got delivered yesterday going to do a leak down test while they're stripped. Has anyone tried taking the mtronic system out? Ive got carbs and ims to replace it with
Last time i split a case i used a heat gun and hammer worked well enough but if you find one at a sensible price could you tag a link always like to have interesting lumps of metal in the shed
Not sure how your coil will act if mtronic or even work, and there’ll be a start position missing, probably warm start. The wiring harness will be different. Could be modified.
If you’ve got a carb 261 you’ll have the parts.
Read more
Expand
Expand
I have the Huztl one for some husqvarna saws which I think works on a number of other saws too.
https://m.huztl.net/Chainsaw-Repair-Tools-c3056.html
I’m tempted to get the screw type, for assembly as well. My problem is it robust enough, are the threads decently cut, are the adapters stamped with part no?
I keep looking at the Stihl one, but the price is high, but your getting a quality tool and able to return if it breaks, and part no stamped on adapters.
Read more
