Sunday maintenance Today I’m afraid.
The tw150 was put away working fine. Next time it came out the preheat was not working. No light / no ticking noise. Electrics aren’t my thing but I’d the likely culprit a simple fuse or relay issue. ? If so can anyone point me to where the correct ones are for the pre heat ?
Many thanks
Ticking is the fuel pump isn’t it?
Possibly the barrel?
I believe so.
But there should also be an audible click of the relay
I changed both the fuel filters and checked the lines so happy there’s no blockage. Turns over but won’t fire so thinking maybe the relay to the pump and glow plugs is gone.
Typically I couldn’t find my multimeter to check it.
Aren’t a lot of the relays the same? Can’t you switch a few to see if you get a light?
I think the light is on a separate in line fuse.
