And now I've checked the manual I realise the max engine speed is 14000rpm, so I don't have to dick around with the carb.
Sometimes I really need to remember to double check the manual.
6 minutes ago, adw said:
Has this saw still got the compensator carb on it?
I took lots of pictures to help remind me how it came apart, so I have some of the carb, mostly covered in filth. Not sure if they help? It's a 2011 saw I think.
Edited by Toad
5 minutes ago, spudulike said:
They came in Walbro and Zama flavours, the Walbro suffers with accelerator pump issues, the Zama was the solution to the issue.
Ah, awesome. Thanks for the explanation. I think it is the Zama carb. I did briefly look for the model/identification when I cleaned it, and remember seeing C3 cast on the body, so I assume it is the C3 EL42 carb.
Quite correct Steve, however there is something strange in those pictures, that's not a 357 filter holder or just a bad picture, and the black plate between the metering diaphragm and cover would say its a compensator carb, but the breather hole in the pump cover would say its not?
