6 hours ago, BowlandStoves said:
Thats stove is a prime example of how they pass the test of time - looks ancient but also looks like it is still going strong.
An interesting side point, do contemporary stoves have the same longevity?
I wonder too. The simpler the better I reckon. If you live rural and have loads of wood, efficiency doesn't matter as much.
Id check the baffle is the correct one and seated properly.
If it smoked regardless, personally i would remove the baffle and either cut a inch or two off or replace with a smaller piece if metal and see if this makes a difference.
Have you fitted a new cowl?
I thought he swept the flu and it all works now ?
