Ash dieback Felling
On 12/10/2019 at 17:05, Charlieh said:
we cut 2.5m 3m and 3.7mtr depending on the straightness of the timber, the site conditions and extraction method. If your using the major pull them all to your loading area as poles and cross cut them there if the ground will hold up and you don't have a forwarder. Remember 3.7s mean a less cutting
Beware of the timber being very unpredictable.
Also best requesting to see info from the woodland owner e.g correspondence from FC relating to the permissions as even on sites with severe dieback you should still have some dialogue with you area officer if your England.
the volume could be quite significant so its worth considering getting a machine in for the extraction as the novelty of loading the atv trailer will wear of pretty fast
Cheers.
I got Felling license on owners behalf
  • 1 month later...
Evening all.. Just thought I'd post an update. Currently around half or just over half way through this site now and all going well. Not easy going doing everything by hand without any machines at present. Hoping to have everything down by spring and then once it's dry enough I can get in to extract timber
  • Like 6
