On a more serious note: :001_smile:
Was the key removed from the tractors ignition and in your pocket/other safe place?
Was there a note or warning sign on the steering wheel/ignition or other obvious place warning of work being carried out on an attached machine?
Was the PTO out of gear?
Were the wheels chocked to prevent movement?
Was the battery earth lead removed if applicable?
Were any eccentric loads acting on the flywheel etc at there lowest neutral point or locked in place? (More suited for bailers etc)
If you are working on your own away from people do they know were you are and what you are doing and when you should finish or be overdue threw absence of contact etc?
Any or all the above would make climbing into a machine much safer. ;)
or simply wait for an accident to happen to you and call a NO WIN NO FEE cliams company lmao:lol::001_tt2:
