I think it was the fact someone was saying that the college didn't use ground helmets anymore, when it turns out they do
  • Replies 42
people are saying that the old pics including the husk helmets are in error, although "chin strap" thread states that they actually do use these old helmets, therefore the pics are an accurate representation of the college, therefore the college is not up to date.
i think
What’s the contradiction? Both threads say the same thing.
Andy
IMO, "Keeping a lid on it" (the older thread) seems to point towards the fact that...
Its old info.
Its the publicity departments fault.
The college uses all the latest tools and equipment.
whereas "chin strap" (a shiney, brand new thread) highlights...
husky knicker elastic lids are sill in use.
If you talk to management they are not interested.
You are better of with your own PPE.
Maybe I will re-read them :blushing:
Edited by Bolt
A Newcastle based HSE officer, is in the process of assessing the 'climbing stlye' helmets after numerous complaints regarding the efficiency of the eaf defenders. The problem is due to the webbing strap not allowing the cuffs to seal against the cheak bone and allowing vibrations/noise to travel to the ear. Anyone else had an issue with these? (the above is fact - He was in my office discussing this earlier in the year)
I do think the assemblies on helmets always will be a compromise, rather tan a solution to the problem. Not only will the straps allow in noise, but head movement, jaw movement (ie chewing gum).When using saws for any length of time I will pop in ear plugs, either as a back-up for defenders or in the summer bin the defenders and just use the plugs. Another advantage in the warmer months is the freer passage of air around your head, helping to reduce heat exhaustion. All the requirements in AFAG leaflet state is hearing protection complying with BS EN 352. It does not state (to my recollection) that 352 must be 352-1 (earmuffs) or 352-2 (plugs)
I totally agree, I've tried several types of plugs, not all are that good, but used in conjunction with defenders they'll give ideal all-round hearing protection. Back to the point you made regarding the strapping interfering with a good seal, ensuring the defender is between the strap each time certainly helps, but can be a pita.
